RE: YS 61S Do I keep it?
One more comment...If your going to be running the engine on a regular basis...I've seen it suggested you don't really need an after run oil with the quality and additives in todays fuels...
I rely on Ultra Oil primarily because most of my engines will be sitting a while before the aircraft are built...And since I re-building most all of my engines I'm using it as an "assembly lube"...
Once I get some plaines in the air and am flying on a regular basis I plan to cut back on the after run oil...
Just My .02
Chuck
