RCU Forums - View Single Post - Making a firewall template
Old 02-27-2008 | 12:38 PM
Missileman's Avatar
Missileman
Default RE: Making a firewall template
ORIGINAL: r2champion
ORIGINAL: Missileman
Using the drawing r2champion posted, along with a compass, protractor and ruler you should be able to figure it out.
Remeber, however, most airplanes require some offset thrust and the engine in alot of cases are not centered on the firewall but are slightly off to compensate for the offset and still have the engine exiting the cowl properly.
An example: I am curently building a Norseman. It requires 2* right and 2* down thrust. In order to have the engine centered in the cowl it has to be 1/8" above center and 1/8" to the left of center on the firewall.
Very true....I guess I looked at it as if the crosshairs marked on his firewall took this into consideration.
It most likely does in an airplane with a box on front like his, in fact I would bet thrust offset is already built in also.
I put out that info in case another beginner read this thread that has a different plane.
