RCU Forums - View Single Post - setting dual rates
Old 02-27-2008 | 05:42 PM
opjose's Avatar
opjose
Default RE: setting dual rates
For my first flights, I set up my throws so that at HIGH rates I'm using the recommended throws in the manual.
For low rates I'll use 50 to 60% of that.
In a corresponding manner I set up the Expo for HIGH rates to be 50% and 20 to 30% on low for ailerons and elevator.
Rudder you want lower so I have it at 35% Expo for high rates and 15 - 20% expo on low rates.
The idea is to keep the plane easily flyable for it's maiden flight...
Then I fly the plane and see how it goes.
If it's two responsive I can bring it in on low rates.
If I find it too sluggish I'll dial up the throws so that the surfaces move beyond the recommended for high rates, but within or less than the recommended for low rates ( remembering to leave in enough elevator for landings ).
I leave the Expo the same, and just adjust the throws.
