ORIGINAL: JoeAirPort
Glad I read this thread. I ordered the Sullivan precision carbon filled rod like RAM3500 recommened. Which one did you use?
Hey Joe, the Precision Ny-Rod is still a hollow plastic tube inside a plastic sheath, its composition is just a little different to make it more stable with temperature change. Although it is black, it still bends and cuts like plastic, and it comes in two sizes for 2-56, and 4-40 threaded rod in the ends. I use it because you don't see changes in the idle when it is very hot out.
