RCU Forums - View Single Post - Simjet 1200 failsafe
Old 02-27-2008 | 09:22 PM
niteflyer
Default RE: Simjet 1200 failsafe
Hi Kerry.......
Thanks for the response. I meet you at the toledo show last year, a nice chat. I have a SpyderJet F-16 with a SimJet 2300 on it (a little too much jet for me right now)
that i was getting some pointers from you for the initial fire..
Anyhow, your correct i have a ECU that is FADEC 2002-D2-R. The plane came with a JR radio, i've been flying with Futaba. Therefore i'm not as familular with it as i
probably should be. In failsafe mode the THRO position is set to -156, but it does say F.S. HOLD so maybe its going to the last good command, which in my case was the
idle position.
A good place for me to start will be the instruction manual for the radio to see if in fact i need to work with the setting in the Failsafe Mode.
Again THANKS, We'll be in touch........
Nite flyer
