ORIGINAL: flyjay77
does it matter how far you hang the sling , can you hang in from like the fire wall and the tail ? would this give the same results? and whats the best way to use this way on a bipe?
jason,
I usually connect just behind the prop and to the prop shaft. On the rear I would connect to the tail wheel allowing the front edge of the horizontal stabilizer to support the sling. The location is relatively unimportant but should be convenient and not damage the airplane.
Bill
