RCU Forums - View Single Post - Great Planes RV-4 .60-.90 ARF
Old 02-28-2008 | 07:48 AM
  #488
skorman
Default RE: Great Planes RV-4 .60-.90 ARF
ORIGINAL: chopper man
I am working on mine. I'm installing the flap servos. On the right wing panel is part of the servo going to hang off of the panel or should I flip it around so that it doesn't. If I do than the opening will be closer to the flap than the panel on the left wing. Manual doesn't do a very go job of explaining that part. I do understand that the servo arm on the right wing points to the wing tip and the left points to the wing root. Thanks for your help.
chopper man
The flap servos are not symmetrical on purpose so you can use a standard Y connector and not a reversing one. You can also opt to plug each flap into its own channel. Great Planes did this to make it easier for people not plugging the flaps into seperate channels.
