RE: Throttle servo interferance?
Good choice of mounting T3. Be sure they contact the lugs evenly or the crank case will have to warp to the shortest one. Soak the ends with CA when you are done sanding to harden them. Next flex up and down on the engine to see how much the firewall bends under load. If there is bending, close in the top of the firewall. Use lightening holes to get to hardware inside the box.
