RCU Forums - View Single Post - Compared to real life...
Old 02-28-2008 | 12:23 PM
opjose's Avatar
opjose
Default RE: Compared to real life...
That was spot on!
One thing I like to do with the Sims is to adjust the physics models so that I throw in more "toe out" on the wheels.
This induces a bit of yaw on the wheel bearing the most weight, as it will grip better, producing a more realistic run-up effect.
Combine that with P and engine torque settings, then throw in wind and thermals, and the sims become great practise tools to get you ready for cross winds and higher winds at the airfield.
Thanks to practising with the Sim ( G3/G4 ), often when winds are over 24+ MPH at our field, I'm the only person out, typically flying a Big Stick, much to the amusement of the Giant Scale crowd who are grounded. You end up looking forward to higher winds and cross winds because it permits you to do other stunts which you cannot normally do...
e.g. hovering the plane as the wind pushes it down the entire length of the field, harrier landings, etc.
