RCU Forums - View Single Post - Spektrum DSP75 servos compatible with GY401?
Old 02-28-2008 | 02:22 PM
gfyss
My Feedback: (14)
Default RE: Spektrum DSP75 servos compatible with GY401?
Yes, Spektrum DSP75 servos will work with Futaba gy401 gyros. The note on the tower hobbies page is in reference to the 8700G servo which is a PCM servo designed to only work with the G7000T gyro. The newer 8900G should work just fine with a gy401 because it uses the standard signaling, but the 8900G has a deadband of zero compared to most digital servos with a deadband of around 3 micro-seconds.
The Spektrum DSP75 can handle the high frame rate from the gyro, the E-flight DS75 can't.
Good luck!
