RCU Forums - View Single Post - insturnment panel
Old 03-08-2002 | 12:25 AM
Scorpionjack's Avatar
Scorpionjack
Default insturnment panel
FS;
I download the specific Instrument panel then print it out in color on Photopaper or Matt finished paper. Then take 1/64th 0r 1/32'd aircraft ply make the appropriate hole over the color template glue them together then fill the wholes with a clear epoxy with no bubbles. Using a toothpick i fill the holes then let it dry. If you want a black dash then use poster paper and do the same as above.
