RE: throttle hesitation
Inertia also applys to the effect on the plane itself, so in addition to the sound travel delay and the throttle up delay, there is the delay before you see the end effect on the plane.
Put all of these together and the plane seems to lag behind by a percievable amount....
Something that may be quite unsettling unless you are used to it.
