RCU Forums - View Single Post - fuselodge hole
Old 02-28-2008 | 07:55 PM
bruce88123
Default RE: fuselodge hole
The hole is small and on the bottom of the "fuselage" where it won't be seen. I wouldn't worry about it. Drill before covering if able at the rear of the fuel tank area (or lowest point). May want to "fuel proof" the hole with a bit of epoxy or thin CA when done. If not the fuel will soak into the wood.
