RCU Forums - View Single Post - Official 9.5 Violator Thread
Old 02-28-2008 | 08:48 PM
  #112
Paradoxmaker's Avatar
Paradoxmaker
Default RE: Official 9.5 Violator Thread
ORIGINAL: Allan Aguilar
ORIGINAL: Paradoxmaker
Hello,
My 9.5/Ravager spur gear for the center diff is slowly wearing off, I will be needing a replacement soon, however, the spur gear only cost a lot of money, what other diff spur can I use (ie. Hyper 7/8/8.5, Kyosho 777 & etc.) and I wanted to reuse my diff case and gears. How about a new center diff assembly for other ofna models. Need your inputs here.
The center diff mount from the Jammin can be swapped out with the 9.5 series, but i do not know if the spacing between the mounts is the same.
If you could measure the distance between the mounting screws (front to back) i could measure my Jammin and see if the entire center diff could be used.
The measurement of the diff mounting screws are 39 mm. center-to-center. Let me know if your Jammin have the same measurement.
Nope, the Jammin center diff is 35mm center to center....So even though the actual mounts are the same, the diffs apparently are different sizes.
