RE: 32cc Poulan Weedeater conversion need input!!!!!!!!
I believe I have the same motor, I was told that a Ryobi prop hub may just work. All you need is a spacer between the flywheel and the prop. I was also told that it would swing a 18x8 prop at a good rate.
