ORIGINAL: Rcpilot
I need to find a place to get those bolts. I might prototype the design and see how it works. I'm worried about it being "floppy". I felt like the outer cabanes should seat on the wing surface kinda snug. If I jack the back end up 1/16" to get negative incidence--then the cabane won't touch the bottom surface of the wing. [sm=confused.gif]
Once you have done your test flights and worked out the incidence you could make spacers so that the wing is solid on the cabanes.
- I too use MS Paint to illustrate for RCU and my random design ideas while I am at work
... it is a very simple program, but can make great 2d drawings to explain things.
