RE: TWIN FEVER !!!
Dear CP, Chuck, or Piggy (which do you prefer? For myself I'm used to being referred to as EL Magnifico but you can call me anything - except "late for dinner"),
I am becoming more and more addicted to foam (as a building material - I tried freezing some as a substitute for ice cubes but the little chunks just floated on the top of my Southern Comfort and I nearly choked on the darn things).
Anyway, I'm too lazy to read all of your earlier posts so if I'm asking you to repeat yourself - tough nuggies.
I have used water-based polyurethane (WBPU) to stick the FG down and to fill the weave. It comes out somewhat softer than epoxy or resin when cured but its definitely lighter. For 10 points, do you use WBPU? For 17 points if you do have you found a magic hardener? 25 points will be awarded if you have found "the best" brand of WBPU? 13 points for what you use for a final finish coat. If you score more than 38 points total I'll share one of my many beauty secrets with you.
