Ok that threw me for a loop
I assume yours have the other set of holes in the front correct?
If so the adjusters go in the front hole. Don't open the bolt hole too much, only enough to pass the bolt. if you find you need to adjust the incidence beyond what the bolt hole will allow (I have yet to see this) then just elongate it SLIGHTLY with a small round file.
-Mike
