RCU Forums - View Single Post - throttle hesitation
Old 02-29-2008 | 02:46 PM
Missileman's Avatar
Missileman
Default RE: throttle hesitation
ORIGINAL: springhillflyer
the engine sounds great, it don't sputter and nothing so maybe its just he speed of sound. someone also told me that if i'd put on a os carb i wouldn't have that problem, but i don't know about that. so i'll have someone hold my plane and i'll walk away and try see what happens....thanx
How will that work?
Think about it. If you walk a long way away and have someone else move the stick you won't be able to see the stick movement (speed of light) so you would have to rely on instantaneous comunication. Your helper can shout when he moves the stick but then you have the speed of sound again compounded by any delay your helper might add in shouting.
Maybe you can use a 2 way radio but I don't know how fast that will be either and some 2 way radios, including cell phone direct connect have a slight delay built right in to prevent feedback if 2 users are close together.
