hover
Although the fazer is pretty short coupled it is a great plane to learn to hover with. Be sure your engine is completly reliable. Balance the plane at the rear of the CG envelope, have some pretty extreme throws on your elevator & rudder. Get a little altitude while you are learning (its actually easier to hover closer & lower) but for now its safer with some height. Point the nose up & use the rudder & elevator to steady the plane. Good luck
Joe
