RCU Forums - View Single Post - question about the Pulse XT 40.
Old 03-01-2008 | 10:21 AM
overbored77
Default RE: question about the Pulse XT 40.
Another good idea is to go through all your linkages after installing the RX. Set all the control
surfaces to neutral with the TX trim at it's neutral point. There is nothing worse during a maiden than
to be in the middle of trimming and find out you've run out of adjustment on the TX, and have to
land while compensating for an out of trim plane. This can happen regardless if the trims are neutral
but you have more of a chance of an easier maiden it the linkages are properly set.
Also check to see that the throws are set where the manufaturer reccomends, maiden at the low rate setting.
CHECK the CG!!!!!
GOOD luck and have a blast.
