RCU Forums - View Single Post - RE : Desperate Beginner
Old 03-01-2008 | 04:30 PM
simplyraptor
Default RE: RE : Desperate Beginner
Ok ... does the movement of the collective/throttle stick go bumpty-bumpty
Do you have a fine ratchet on your throttle stick or does it move smoothly, if it is a fine ratchet you need to turn the ratchet tag over to make the stick move smoothly this will give you a finer pitch and throttle response and smoother control of your Heli.
