I'm a bit confused probably because the information is way over my head
To dumb the question down to help me get the answer I am looking for...
Other than the actual run time because of the mAh difference, will the following batteries work the same?
Lipo 5000HV 2S 7.4V Pack
[ul][*] 5000mah Capacity [*]7.4 Volts [*]45mm X 138mm X 18mm [*]20C Constant(100 amps) [*]30C Sustained(150 amps) [*]50C Burst(250 amps)
[/ul]
Lipo 8000HV 2S2P 7.4V Pack
[ul][*]8000mah Capacity[*]7.4 Volts[*]44mm X 137mm X 26mm[*]20C Constant(160 amps)[*]30C Sustained(240 amps)[*]50C Burst(400 amps)
[/ul]
