RCU Forums - View Single Post - Pull-Pull on the Knife?
Old 04-23-2003 | 12:53 PM
TERMAGATOR
Default Pull-Pull on the Knife?
heres a pic, I run the cable thru the brass tube, then thru the servo arm, back thru the tube and then bring back around on the outside of the tub and back in thru the same opening you went thru on the 2nd pass, pull it tight and then crimp the tube with pliers, heres a drawing
