RCU Forums - View Single Post - question about the Pulse XT 40.
Old 03-01-2008 | 11:45 PM
mesaflyer
Default RE: question about the Pulse XT 40.
ORIGINAL: F-15 Fan
These are some things I need to know before I maiden it today.
Do I have to glue anything on the wings, or do I just slide them together.d
To answer your question, just slide them together. It does not get glued. Makes it easier for transportation. If you mounted your engine sideways, you will probably want to put an exhaust deflector on it. If not, the oil will work it's way to the mounting bolt plate. Not good. Make sure all your controls are moving the correct direction. Double check your CG. It makes a big difference the way it flys, especially landings, if it's only a little off. Have fun. I have the ARF, and it is a blast to fly.
