RE: 50cc Sukhette Build Thread, now in progress!!
It depends on how tight is tight. If it's just a little tight sometimes I run a Dremel sanding drum (GENTLY!) around the inner edge to take off burrs and high spots in the fiberglass. Often this will be enough to give some clearance.
TF
