RCU Forums - View Single Post - HPI Nitro Compression
Old 03-02-2008 | 02:44 PM
avg_joe's Avatar
avg_joe
Default RE: HPI Nitro Compression
Unless you have a way to spin the engine at an exact RPM for each test, I don't think you are going to have success with compression tests.
The only way I know to check the compression is the 'thumb gauge'....Roll the flywheel with your thumb against the compression with gentle, steady pressure. If it bleeds pressure off quickly, then it doesn't have good compression.
Also, another 'gauge' of the overall health of the piston/sleeve fit would be the degrees of revolution in the pinch. Without the plug in, roll the engine through the pinch zone and see how many degrees the flywheel turns. In a worn out engine, you will barely feel a squeeze, where a new engine has significant resistance through the pinch.
Nothing scientific, or easily put on a graph...as far as I know.
