RCU Forums - View Single Post - The Arrow Rebuild
Old 03-02-2008 | 11:33 PM
rabraaten
Default RE: The Arrow Rebuild
I don't have enough experience building to know what I can't do...HAHAHA. So far it looks easy enough. The aileron torque rods were cut out of the wings and swapped side for side putting the control side of the rod facing up though a newly drilled hole. The servo is going to be mounted dead centre in the wing as opposed to the off centre original location. By my crude measurements I'll move the servo tray up about an inch or so in the fuse and flip the servos inverted. Make a cutout in the fuse for the wing which will be modified to bolt on. As you can see the fuse will be a bit shorter in height as I change the configuration but hey....isn't that what a rebuild like this is all about....I'm sure the maiden will be far more interesting than the rebuild ever could...
