RE: pull pull system
Usually the wire is secured to a threaded portion which mounts to a clevis, which is attached to the control horn, to allow for some adjustment. That is the method I have used for a pull pull setup, you could just loop your wire through the horn and secure with a brass or other short length of metal tube that is crimped to hold the wire, but I would not do it like that.
