RE: FG 2 speed to single speed. What parts do i need?
i have 2 speed on my beetle.
if you want to run with 1 speed, buy the correct size pinion and spur for 1 speed, you cannot use the 2 speed gear carrier as the dimensions are different..you will need a new 1 speed carrier,
take of the 2 speed pinions, spurs and clutch....fit the 1 speed pinion and spur...easy//
the reason clutch bell is mentioned is, the 2 speed clutch bell has a longer shaft to accomodate 2 gears..but i see no reason why you would need to change it to run 1 speed, if you dont chnage it, you can easily switch back to 2 speed if you please.
