RCU Forums - View Single Post - Tail going counter-clock -- servo is already maxed out
Old 03-04-2008 | 12:01 AM
BladeCX2Two
Default Tail going counter-clock -- servo is already maxed out
Hey guys-
I'm having a new problem with my Belt CP. I can't seem to get my tail from going counter-clockwise without giving it a good amount of tail to the right input. I've already maxed out the the throw on the tail blades and actually wrecked one servo by trying to go to far and in turn stripping out the gears inside the servo. The tail blades are spinning in the proper direction. There aren't any nics or breaks in the tail blades either.
One thing I can tell you is that I just put on a set of brand new balanced Align 325 carbon blades on Thursday. I know the stockers are 315mm so I'm adding on an extra 20mm of rotor span. Do any of you think that my problem is the tail blades themselves in not being long enough to compensate for the longer main blades?
I just got done rebuilding most of the head assy tonight due to a mishap on Friday. Somehow my ESC went into brake mode and when my blades hit the gound, it sheared off the plastic upper head. I just got done running it outside and other than having to hold the tail stick pretty far to the right, it flies pretty darn good. I don't know when else to try.
Thanks.
