RE: KYOSHO GXR28MR NITRO ENGINE
Turn the high-speedc needle counter-clockwise to richen the carb, you may have to go 1/2 turn or more out. When you blip the throttle you should hear a slight lag. The load of the prop once in the water will lean it out just a little more.
