Flapron and aileron diff
Hi,
without connection for how to set it up on my specific radio ( Radiant ).
i am using two servoes for ailerons ( channels 2,6 ), and the flapron function is switched on.
now when the flaps switch is turend off each aileron goes up and down for about 30 degree accordingly, now when appplying the flaps both ailerone goes down for about 20 degrees.
The mechanical down movment of the ailerones is limited for 30 degrees ( even when the pushrod is disconnected ) ,
so my question is how to set the radio that once applying the flaps, moving the aileron stick to the maximum on both sides will cause one aileron to go down for 10 degrees and the other up for 50 degrees accordingly.
in the current situation no matter what is the flap position both aileron goes up and down for 30 degrees fro that point.
Shlomo
