ORIGINAL: jrf
It's a Vmar. Probably a 60 size. The 70 is more likely to be too small than too large.
It may be the same size as the Hanger 9 PTS but I think you will find an extra kilo in the Vmar version.
Jim
Hi again. I've been looking at this again because I've been thinking about the exact CG and control throw recommendations. I finally did determine that you were
not mistaken about it being vmar. They upgraded the ARF at some point changing how the wing is mounted etc and totally changed the look, but much of the construction is very much the same still. I got the manual for the current version and it might be good enough, but I'll still write to them and ask if they have a copy of the old manual.
How the new one looks threw me off the trail initially and the website is a little unclear about there having been an earlier version of it, but I finally know for sure now.
Thanks again for pointing me in the right direction
Great help to be able to track this down.
ORIGINAL: MerlinFan
Try Richmondrc.com for vmar
That info too helped solve the mystery
Cheers
