RCU Forums - View Single Post - Strange clutch problem
Old 03-04-2008 | 12:40 PM
MadMatt2024
Default Strange clutch problem
I searched but couldn't find any information on this problem so I hope you guys can help me. After a few runs the clutch shoes on my Volcano jump over and get stick on the e-clip that holds them on. This causes the clutch to be slightly engaged constantly, causing the truck to want to jerk forward. It also makes it more prone to stalling and if I raise the idle to were it won't stall it goes by itself. This happened once before and I just pushed the clutch shoes back to their regular position and it was fine for a while. This time however one of the pins that the shoes fit onto also worked its way out part way, I put some Loctite on it and put it back it. I know the shoes will work their way out once again and I need to fix this. Any suggestions?
