RCU Forums - View Single Post - Avistar Elevator Throws
Old 03-04-2008 | 03:23 PM
mclina's Avatar
mclina
Default RE: Avistar Elevator Throws
If your elevator is at neutral with no stick input and zero trim, then the difference is probably just a result of the geometry of the control horn and pushrod setup. I really wouldn't worry about it. You shouldn't be giving it full elevator travel while flying anyway, and it's better to have more than you need than to run out of elevator when you need it (inverted and approaching the ground ).
You should be fine.
