RE: Engine Kill...By choke servo or by ignition kill
The problem comes with the higher power to weight ratios of the 3D planes (I assume your flying 3D since you are talking about a DA85). There is no way I could land my yak at anything above 1/4 throttle, without doing damage to the airfame. And no, my yak is not overpowered for a 3D plane, it will hover at about 2/3 throttle.
If I were to have the throttle servo/linkage fail, I have the choice where/when to kill the engine so a controlled landing can be made with no damage to the airframe or the prop for that matter.
And you really don't have a choice it the matter, the plane will come down sometime. I just like to be able to choose when/how that happens.
