RCU Forums - View Single Post - Tail going counter-clock -- servo is already maxed out
Old 03-04-2008 | 04:24 PM
evdreamer
Default RE: Tail going counter-clock -- servo is already maxed out
I have 320mm blades on my Belt CP and have no problem. Do you have zero pitch on the tail blades with no rudder input? If not try moving tail servo, most likely backwards toward the tail. Are you in HH mode or standard rate mode when this happens? How high is your gain on the gyro?
