ORIGINAL: soarrich
How does the velocity stack work? Is it that it holds the air/fuel mix there to be suck back in? or is it ramming the air keeping the air/fuel mix from coming out?
In a very basic sense it holds the escaping charge there until it can be pulled back in, but it also helps the flow of the air into the venturi and can increase power. (if done correctly)
