RCU Forums - View Single Post - Brake on a Esc ?
Old 03-04-2008 | 05:02 PM
BigTb17
Default RE: Brake on a Esc ?
All I can tell you is what I like mine for. I have a foam plane with no landing gear which I simply plop onto its belly to land. In that situation I have the brake enabled so the prop stops as quickly as possible when I cut the throttle so the prop is no longer spinning when I touch down. This is all I have used mine for, but I am sure there are other reasons.
