RCU Forums - View Single Post - Carb Block Plastic type material?
Old 03-05-2008 | 10:50 AM
tim220225's Avatar
tim220225
Default RE: Carb Block Plastic type material?
No need to buy it 3 inches thick. Buy 3/8 to 1/2 inch thick at most. I bought 3/8X2X24. I also use Acetal on some and have had good luck with it. Either can be machined. The G10 and the Acetal drill and tap very well. I cut the material with a band saw then contour it with a belt sanding center machine.
