ORIGINAL: fancman
ORIGINAL: BaldEagel
I am just building a new 50cc gasser and its going to have two Rx's which of course need two battery systems each, which means four power boxes as well, so thats four switches which could fail so I will double those as well, opti kill switch for the ignition of course two of them double aileron servo's just in case and I better put two rudder servo's on and do I need four elevator servo's in case the servo on one side goes west, I think I will be able to keep the weitght down to around 25Lb's for the 85" span, does this sound OK.
Mike
LOL Exactly my point. Looks like you're on the right track Mike. I'm getting ready to put together a 35% Yak so with all the redundant stuff I apparently need I should be able to bring her in just under 100 lbs.
There is a saying in general aviation regarding twin engine aircrafts:
"The second engine will make sure you arrive at the scene of the accident" and that's truth of any redundant system.
Ask the designers of the shuttle Columbia if their quadruple redundant computer systems could have prevented their disaster. My point is that it doesn't matter what we do to prevent a catastrophic failure fate has its way in the end, but
that doesn't prevent engineers from trying to increase the odds in our favor. Of course you must exercise an analytical decision making process when designing your system. That means evaluating every component and then deciding which options satisfy your mission requirements. In my opinion in the case of a 3D machine, which options will be the lightest, most reliable, easier to install, and least expensive.
In any case I don’t see how a 0.3 oz. optical kill switch is going to ruin your 30 lb. plus 110” wingspan, overpowered 2.5:1 3D machine wing loading. Or for that matter the cost of such unit is not going to drive you directly to bankruptcy court because you are going over budget on your $3,000 dollars project.
