RCU Forums - View Single Post - weird prop question
Old 03-05-2008 | 12:33 PM
CGRetired's Avatar
CGRetired
Default RE: weird prop question
You want to try to pull around a 40 size plane with a 25 engine? Ok.. let us know how that works out.. and if it even gets off the ground.
You will need something with enough pull to get airspeed up, and enough power to hold it there. You may get the thing up, but I imagine that you will be at full throttle no matter what prop you select. So, select something with a good diameter and a good pitch.. perhals 9-6 may work? Then again, the engine may not get enough RPM up to place it in the power band.
CGr.
