RE: FUNJET
This is what I'm "remodeling too."
1- overall view and layout
2-side view
3-new exposed motor to improve cooling and prop bite=more speed- better performance
4-rear-ESC & motor--I will mount esc under the deck and place a scoop above to ram air around esc and exit in front of the motor
6-canopy -looking back--little larger canopy to start--for bigger batts.--may reduce height after testing
Have to patch the hole on the left front nose as the CF pushed thru. Will install 2 smaller tubes down the sides to replace the old 1 which I removed ( shattered)
I didn't look that close when it crashed as I was really mad and myself and the equipment. Now it's not really bad. Oh the rx wire was cut ??? I have to fix that --no problem there.
