RCU Forums - View Single Post - Twist 3D 150 ARF
Old 03-05-2008 | 08:43 PM
  #644
linkadrip's Avatar
linkadrip
Default RE: Twist 3D 150 ARF
Had foam between the camera and the fuselage. but it didnt seem to help much. Going to locate it in a different place next time and will make sure it's righ side up.
Heres some pictures of the camera used you can find them on ebay. I have a 2GB SD card in mine otherwise the video is only a few seconds. But hopefully the next video will be better if not then i wont post it.
I had to make a Camer holder for it with a mirror on it to mount it were is would shoot video foward so the camera can lay flat. other wise you have to mount it to the side of the plane mine was mounted on top of the tank hatch. a little to close to the engine. And it picked up alot of vibration. Have to tak a picture of it. then it will be easier to understand what i'm talking about.
Going to to some mods now that i have it appart Re enforce the lading gear area and going to move the RX battery back behind the cockpit and make the whole front underside solid. lots of epoxy. Heres some pics of the damage its not too bad just glad i belly landed and it wasn't a nose plant. Wing didnt suffer any damge so i'm releived.
ID:	895804   Click image for larger version
ID:	895805   Click image for larger version
ID:	895806   Click image for larger version
ID:	895807   Click image for larger version
ID:	895808   Click image for larger version
ID:	895809   Click image for larger version
