RCU Forums - View Single Post - Problem with mesh.....
Old 03-05-2008 | 09:46 PM
drivefastgto's Avatar
drivefastgto
Default RE: Problem with mesh.....
If the pads on your new spur gears really are a lot thicker, that's more than likely your problem, assuming everything was OK before you stripped the first one. From what you posted, this sounds like the only thing that has changed.
What part# are your replacement spur gears?
