RE: battery doesnt charge
I usually charge mine the night before every time I fly.
Depending how much you used your starter,etc, 4 days of flying is quite a bit.
Are you saying it won't hold a charge?
I would open up your field box and hooked the alligator clips directly to the battery and try that. You may have a loose connection somewhere between the batter and charging jack.
