RCU Forums - View Single Post - Inverted engines, need advice.
Old 04-24-2003 | 12:49 AM
Crashem
Default Inverted engines, need advice.
Make sure your fuel tank is correct. When an engine is inverted the carb is bellow the fuel tank which can cause flooding. Alot of engine problems can be traced back to impoper tank installation/positioning. I was allways taught that the fuel tank should be positioned so that the fuel line was inline with the fuel connection (nipple) on the carb. Run it on the ground at different throtle setting and test it.
