RE: Twin Screw Question
Good question. I am just finishing a Shelly Foss, and I assumed figure 1 would be correct, as it would draw the water from outside and push it down in the center away from the hull instead of pushing it up against the hull. Easy enough to change once I run it to see if it changes performance. It would be interesting to see if it makes a difference on a tug vs. a faster hull as well.
