RE: Tail going counter-clock -- servo is already maxed out
Hey guys- I really appreciate your responding to this. I took it out again after work. I did what you said by increasing the head speed by dialing down the left knob (hov.pit).. head spead increased but also took more rpm to lift off. This helped the nose a tiny bit. It was the knob on the right (pit trim) that made a bigger difference. I dialed this knob all the way down. Doing both of these helped but still isn't enough. In saying that at least it proves the theory of needing more tail thrust like you guys said. With the 325's on there, it's just too much for the tail to compensate. Also keep in mind, these are 325 fiber blades not wood, which I think are heavier than wood. Maybe that's why you other guys aren't having problem with your 325's...maybe you have wood ones. I love these blades and plan to stick with Align. I just had too much problems with the coverite material coming off the stock blades. Plus these seem way more stable.
Just a few moments ago, I ordered 2 sets of Align 315mm fiber blades, plus 3 sets of Align 450 carbon tail blades. They all should be here by early next week.
Thanks again for your advice.
